Use the following procedure to view or clear statistics of the number of packets mirrored into I-SID on the mirroring BEB.
  1. In the navigation pane, expand Configuration > Serviceability > Diagnostics.
  2. Select General.
  3. Select the Isid-Mirroring Stats tab.
Isid-Mirroring Stats Field Descriptions
Use the data in the following table to use the Isid-Mirroring Stats tab.
Name
Description
Index
Specifies the entry that contains Fabric RSPAN statistics information.
MonitorIsid
Specifies the actual monitor I-SID value to which the packets are mirrored.
MirroredPackets
Specifies the number of packets mirrored into I-SID on the mirroring BEB.
ClearStats
Clears the Fabric RSPAN statistics.
